Ignition Timing A12
From adelaide hills
what is the norm. timing.
my a12 is on 10 deg and is running o.k ish and is not burning the fuel properly ( lots coming out the exhaust)
Please Help
Posted on: 2008/7/15 6:55
1977 1200 ute aka franky weekender
1979 sunny wagon aka rod the second daily
Re: Ignition Timing A12
Not too shy to talk
From Gold Coast
hey champ it in the wiki. go into the wiki page and search ignition timing
Posted on: 2008/7/15 7:26
From Bendigo, Victoria, Australia.
normal timing should be set at 7deg btdc. If you have unburnt fuel coming from the exhaust i would start with a set of plugs and points, set the idle speed/mixtures, set ignition timing and dwell angle.
Posted on: 2008/7/15 10:47
"Like a Rolling Stone"
Bob Dylan
New Daily: <<<<Now For Sale.
1972 B110, 13" Bathurst mags, airbrus
From adelaide hills
looked on wiki and did the procedure
put a new set of plugs now have 5 deg btdc and did the dizzy gap, and dwell now it runs alot better BUT it has less low rev power than it did b4
Posted on: 2008/7/15 10:52
From Adelaide, Australia
Posted on: 2008/7/15 10:53
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
From adelaide hills
Cheers Guys
Thanks 4 the help
keep the info comin'!
Posted on: 2008/7/15 10:57
