Has anyone used SUPRERTECH Pistons ? (CA18DET)
From Melbourne ( West )
Has anyone used SUPERTECH Pistons?
or know of anyone who has?
Below is the article for them...
They have been around for a while, seem reasonably priced and by the description - sound good.
________________________________________________
Supertech - High Performance Pistons w/Rings
Includes Pins & Wire Locks
Nissan CA18DET
More than 40 years of experience in the design of racing pistons and the utilization of the latest CAD software & Finite Element Analysis (FAE) enables us to design strong high performance and yet light pistons for each application.
Compression ratio was computed with .030" head gasket and .010" deck.
A phosphate dry lubricant coating is applied to most of the pistons to protect against ring micro welding and enhance skirt lubrication.
Our pistons are manufactured from extruded high silicon, enhanced 4032 alloy (with additional Cu, Ni & Mg) that has low thermal expansion, excellent wear resistance and higher thermal conductivity.
The pistons are submitted to several machining steps in specially designed machines and in conventional CNC machines with special diamond tools for dimensional precision, perpendicularity and flatness of the ring grooves.
Features:
Posted on: 2008/7/18 9:24
'78 Ute CA18det Project
No matter where you go... There you are
Re: Has anyone used SUPRERTECH Pistons ? (CA18DET)
From Brisbane
how much are they?, never heard of them
Posted on: 2008/7/18 10:30
They are $399 US Dollars from Import Performance Parts (online)
Posted on: 2008/7/18 10:34
