Bottom radiator mounts.
From Ballarat Victoria
Hi All,
Im wanting to know what cars have the round bottom rubbers with a hole in the middle where the pin on the radiator locates.
Ive built a radiator for the coupe and will weld pins to the bottom of each tank so i can use this type of rubber mount.
Ive seen the ones on commodore radiators but was looking for somthing smaller.
Any ideas?? Thanks
Posted on: 2008/7/21 6:05
VIC DYNO HIRE
Re: Bottom radiator mounts.
From Canberra
S13 possibly, the aftermarket s13 radiator I have came with the pins on the bottom, i assume to mount to the standard s13 rubbers. I just used cable ties
Posted on: 2008/7/21 6:12
Thanks, I was kinda hoping they might be on something common, Does anyone have a pair they`ll part with?
Cable ties? good suggestion, but ive used them all on the engine mounts!!
Posted on: 2008/7/21 6:20
VIC DYNO HIRE
From SE Melbourne
I think N13 pulsar and probably Pintara should have the same mounts too?
Posted on: 2008/7/21 7:05
Mildman, Datsunless
Sounds good, thats what im looking for. i`ll have to get to a wreckers in the next couple of days.
Thanks for the pic.
Posted on: 2008/7/21 7:20
VIC DYNO HIRE
From SE Melbourne
No problem
I remember at the wreckers when looking for top mounts for the radiator - I noticed that a lot of nissan from the mid 80's to early 90's had very similar radiators....the mounts on the top looked very similar - so I just assumed they were mounted at the bottom the same way.
Posted on: 2008/7/21 9:43
Mildman, Datsunless
From The garage, NZ
i used an n13 radiator in the wagon and by the sounds of it thats exactly what your looking for. Easy as pie to install.
Posted on: 2008/7/21 10:06
