patrol booster
From morwell vic
has any one used a patrol GQ clutch booster as a brake booster it loks very similiar to the on maddat uses
Posted on: 2008/7/22 10:49
Re: patrol booster
From Geelong, Vic
wonder if they are the same as skyline ones, just saw one on ebay and it looks smaller than a 120y booster
also has a smallish looking pushrod so wouldnt need to space it away from the pedal
skyline clutch setup on ebay
Posted on: 2008/7/23 6:30
Re: patrol booster
From morwell vic
i have bought one of these and im going to give it a go im running a 1973 potrol master cylinder running with a ca18dat what other setups have people used !!!
patrol booster
Posted on: 2008/7/23 11:44
Re: patrol booster
From Geelong, Vic
so the skyline one is smaller, id almost be putting money on the patrol booster being the same part as a 120y brake booster
Posted on: 2008/7/23 12:33
Re: patrol booster
From morwell vic
but the 120y ones are starting to get hard to find
Posted on: 2008/7/23 12:50
Re: patrol booster
Not too shy to talk
From Adelaide
your right about the same size but if you look closer the bolts on the face for the master cylinder to bolt to the studs are opposite. so if you bolt the datsun master cylinder to it the pots will be laying flat.
Posted on: 2008/7/23 13:26
Re: patrol booster
From Geelong, Vic
OR...... you rotate the booster 90 degrees
providing the bolt spacing is right
cant see vaccum really knowing which way is up
Posted on: 2008/7/23 13:29
Re: patrol booster
From Brisvegas, oz
dont know how old this thread is but im just wondering how it turned out?
Posted on: 2008/9/21 11:18
www.camerasplus.com.au
