Dodgy Fuel Gauge, help?
Not too shy to talk
just bought a datto ute and the fuel gauge has a mind of its own, sometimes its half a tank and next its nearly empty??? any ideas where to start, any help would be much appreciated!
Posted on: 2008/7/28 11:42
Re: Dodgy Fuel Gauge, help?
From SE Melbourne
There is a wire on the top of the fuel tank that sends the fuel signal....here's a pic of it from my coupe - if your lucky you might have an easier time of it with the ute.
Posted on: 2008/7/28 12:41
Mildman, Datsunless
From Oberon NSW {Bathurst}
Is your temp gauge working or is it miss reading as well?
Posted on: 2008/7/29 5:09
Cheers Peter.
nos4datsuns@bigpond.com
peter.maxsted@bigpond.com
0427 138 266
THIS YEARS RIDES & PROJECTS:
Tweaked 2009 AURION SV6(Daily)
Ha just make sure you have a jerry can with you at all times then it doesnt matter if your fuel guage wont work. Remember its a 30 year old car it aint that accurate.
Posted on: 2008/7/29 6:17
Don't You Just Love Owning a Road Registered GOKART
Not too shy to talk
cheers guys, the temp gauge isn't working either! both fluctuate
Posted on: 2008/7/29 11:58
Your Ballast Resistor that controls your gauges is shot!
Posted on: 2008/7/29 22:37
Cheers Peter.
0427 138 266
If your fuel & temperature guage needles are wandering all over the place then the 'instrument voltage regulator' has gone faulty.
I had one go 'off' in my old B10 sedan & another in my 200B so it's not an unknown problem.
The instruments work on a lower voltage than the system voltage, as low as six volts I'm told & a seperate voltage regulator is used to keep this under control.
I do not believe that it is a simple Ballast Resistor, but whatever it is, find either a new one, or a serviceable used one & fit it. They are not particularly expensive, or difficult to fit.
Posted on: 2008/7/30 1:14
Love your Datsun.
Treat it well.
Not too shy to talk
thanks for your help guys, i will take a look!
Posted on: 2008/7/30 11:24
