Browsing this Thread:
1 Anonymous Users
200b struts into Later model ute, 1980 |
From Adelaide
Hey guys, i have just brought the maddat suspenison set up, rx7 brakes and 200b coilover suspenison i have been using the search button and cant find much info about what needs changing on the later model utes, i have pm'd cpl people and they all said different stuff.. PLZ HELP Cheers, Ben
Posted on: 2008/8/7 6:07
Re: 200b struts into Later model ute, 1980 |
From Geelong, Vic
technically all you need is stanza steering arms...then they will bolt in but you really should go stanza or sunny balljoints and outer tierod ends as well
mystery solved
Posted on: 2008/8/7 6:11
From Adelaide
why should i go balljoints and outer tie rods?>
lol this is different again from wat sumone esle said HAHA
Posted on: 2008/8/7 6:21
From Adelaide
oh also, isnt if i use stannza outer rods and ball joints the steerin goes out 30mm?
Posted on: 2008/8/7 6:28
From Geelong, Vic
dont listen to other people
should go stanza/sunny balljoints as they are 8mm ish longer than late ute ones. without this extra length you will be stuck with positive camber(without the use of camber tops that is, if you can pull the tops in say 15mm you should be right to leave the ute balljoints) extra track width is about 15mm per side, half from the balljoint and half from the hub being out further stanza/sunny outer tierod ends, as they are apparently different to stanza ones....but i dont know if they really are
to do the strut swap from basics you need
late ute/120y, or stanza/sunny control arms late ute/120y radious rods stanza/sunny balljoints stanza/sunny steering arms stanza/sunny outer tierod ends stanza/sunny tierods
you already have the first 2 the balljoints are longer giving some camber steering arms are needed so the struts bolt on outer tierods ends....debatable, possibaly the same as 1200 tierods.... debatable, some say you need the longer ones but im using 180b which are the same length as 1200 ones
Posted on: 2008/8/7 6:31
From Adelaide
ok, stupid question time, where are the steerin arms, im lookin at the pic below cant work it out
Posted on: 2008/8/7 6:42
From Geelong, Vic
knuckle arm in that pic
Posted on: 2008/8/7 6:53
From Adelaide
ok cheers, pigdog, ya a legend and i guess the outer tie rod joins to it
Posted on: 2008/8/7 6:56
From Geelong, Vic
yeah thats the one, side rod in that pic
Posted on: 2008/8/7 6:59
From Adelaide
just so everyone knows, if u got the later ute, u dnt need the outer ball joints GRR
lucky there only 15 bucks
Posted on: 2008/8/7 8:46
