Fuel tanks?
From Bendigo
Hey was just wondring if all 1200 fuel tanks are the same? Im buying one for my wagon and just want to be sure before i buy it that it will fit? Cheers Ed
also its 71 model
Posted on: 2008/10/6 7:07
Re: Fuel tanks?
From Geelong, Vic
sedan ute and coupe ones are all different
so id say that a wagon one is most likely unique to a wagon
Posted on: 2008/10/6 7:20
Re: Fuel tanks?
From The garage, NZ
my wagon one is definately different to my utes one and ive seen sedan ones and coupe ones too.... all different. Which kinda sucks in a way
Posted on: 2008/10/6 8:38
Re: Fuel tanks?
From Schofields
ijust had a thought - i know tht's dangerous as i shouldnt really think!! - would the fuel tank from a Pintara wagon fit the 1200 wagon? Had a thought a while back about putting a Pintara wagon fuel tank into the ute as it will fit so i've been told so i assume it should fit the 1200 wagon..interesting this discussion tho as depending on what else fits underneath i might change my wagon's fuel tank too.
Posted on: 2008/10/6 8:48
Re: Fuel tanks?
From Bendigo
Maybe i might just take the one out and try and find whats wrong with it. If i put anymore than about 12 litres in it smells of petrol and also the gauge doesnt work.
Any ideas why it would smell like petrol with over 12 litres? Hope it's not cracked!
Cheers Ed
Posted on: 2008/10/6 8:59
Re: Fuel tanks?
From The garage, NZ
what smells of petrol? the inside of the car? everything? crawl under it and check the lines to see if anythings leaking. or maybe the top of the tank/the float top is not sealing. Could be a few things
Posted on: 2008/10/6 9:29
Re: Fuel tanks?
From hastings,vic
check the breather lines; if like sedan it has plastic tees and lines go brittel. check breather on filler as well
tommo
Posted on: 2008/10/6 10:15
taking up room at home
hzj75 cruzer tray(for sale)
and allways changing
Re: Fuel tanks?
would be one of the rubber lines or the filler neck hose, they all persih especially if left sitting for a while. try that first.
Posted on: 2008/10/6 10:29
