battery discharging
can anyone tell me what to check for this problem? alt is good???
Posted on: 2008/10/24 21:40
Re: battery discharging
From Tamworth , NSW
your battery could simply be shagged.
Posted on: 2008/10/24 22:13
From Adelaide
Easy check is to disconnect the battery last thing at night and see what state it is in next morning when you need to start the engine.
If it is flat, then battery is not retaining a charge and is discharging internally = KAPUT!!!
If it is healthy, battery may be discharging via some load in the harness.
That is also easily checked but see how you go with the o/night check first
Posted on: 2008/10/25 2:22
Nissanman - just trying to help...
