CA18de into datsun sunny
From Stratford, victoria(the east side of melb)
hey guys i picked up a ca for 300 bucks and i wanted to kno what i need to fit the ca into the sunny
i already have complete stanza front an rear end in the car.
will the master cylinder for the slave cylinder get in the way of the efi manifold ?
thanks in advance Ryan
Posted on: 2008/12/3 1:06
Re: CA18de into datsun sunny
From Geelong, Vic
make or buy new engine mounts to fit the engine, if you use a stumpy R30 box with CA bellhousing or a CA20 non efi gearbox then you should be able to use a stanza gearbox crossmember, and will also be able to use stock stanza tailshaft if using R30 stumpy box
and the shifter should come out the stock position if its in the same place as in stanzas
should be plenty of room in the engine bay with the CA in there so i doubt that either brake or clutch master will be in the way of the plenum
Posted on: 2008/12/3 2:26
well i am having trouble with my tailshaft atm i am using an r30 gearbox but i shill have to shorten my stanza tailshaft to make it suit and it getting quite annoying. i want the shifter a bit further back anyway coz its too far away
and with engine mounts i got told to use 180sx S1 mounts? but i want more info before i jus go ahead and get them
Posted on: 2008/12/3 5:33
