Vanette Drum to Drum Diff F/S
From Wallan, Vic, Aus
Hello, I have a Vanette diff in its houseing, drum to drum I would like to sell.
I tried using it in my 120y, therefor it has some home made mounts on it (I used to be a welder) and it bolts in. But it made the car handle like crap as is has a wider track.
But if anyone knows how to weld, then this diff is fine, you'll just need to remove the mounts and do what you will with it. I have no use for it anymore, so make an offer. Diff centre is fine, no noise etc.
Inspection welcome.
Posted on: 2008/12/8 9:08
Re: Vanette Drum to Drum Diff F/S
From Stratford, victoria(the east side of melb)
h165 or 190 ?
what ratio ?
Posted on: 2008/12/8 9:45
Hi, im not sure what ratio, but it is the bigger diff which has the 10 bolts holding it in. I can't remeber, but I think I was told it is a H190.
Posted on: 2008/12/8 9:48
From Albury
The 10 bolt diff will be the H190
Posted on: 2008/12/8 9:52
Thanks for that Info . :)
Posted on: 2008/12/8 9:57
bump
Posted on: 2008/12/9 9:18
ah come on, bump
Posted on: 2008/12/20 2:35
