brakes
From dominican republic
hello i have the nissan 1200 pickup truck and i want to adapt disc brakes but i dont know of what type of car i can adapt the brakes please help because the drum brakes do not stop very well help!!!!!!!!!!!!!!!
Posted on: 2009/1/10 21:14
Re: brakes
From Nyngan, nsw Australia
for a easy swap use 1200 coupe (B110) or (B310) 120Y front disc's, the whole strut conversion, no booster needed there,
P.S just remmber late 120Y's hub center are larger than 1200 coupe's, as i found this out when using skyline standard steel rims, just depends on what wheels your going to use in the future.....
Posted on: 2009/1/10 21:33
living is good,.....
Re: brakes
ooook thanks i will try those
ok i would like 14
Posted on: 2009/1/10 21:50
Re: brakes
try "wiki".....encyclopedia,
theres abit of info there for you aswell on this subject....
Posted on: 2009/1/10 21:59
Re: brakes
<-- wiki clicky wiki.datsun1200.com
Posted on: 2009/1/10 22:47
Re: brakes
echo echo.....dd
Posted on: 2009/1/10 22:57
Re: brakes
From Christchurch NZ
get the 1200 or 120Y disc brake struts, and fit up some S13 brakes to them. I've just done some hard driving over some steep hills, and they refuse to get hot and fade out.
Posted on: 2009/1/11 2:14
Forced Induction!
Re: brakes
hey force with s13's will they fit straight onto the 1200/120y stub axle with any hassle?
Posted on: 2009/1/11 4:56
