Engine swap - Half-way through.
More like 3/4 through and man I wouldn't want to do this for a living.
A few problems encounted include engine mounts not lining up properly (new bolt holes fixed that) Gear box mounts either (reversed now)
Whilst stripping the A14 I had it cleverly mounted on the ground but after taking the alternator setup, intake and exhaust then turning away for 1 second BAM the engine ends up on it's side. Broken dizzy cap and one of the clips that hold it on too! And I was just about to remove the pushrods but half of them ended up bent after that. Ohh well.
Gearboxes were different length so I had to use a different drive shaft. Getting the damn shifter in and secure was a mega pain in the arse. Just couldn't get the holes to line up to get the shaft through.
Couple of scratches here and there from removing/installing the engines.
After taking off my GX head I found where one of my weber's butterfly screws ended up too. Ended up in one of the cylinders and damaged a portion of the combustion chamber. You can see distinct thread marks on the surface.
The car was running OK from what I could tell, wasn't pinging or blowing smoke or anything but can/would you get this machined?
All in all I had a great time getting really dirty.
So what's left to do? GX back on (pending) hook up extractors and intake side of things. Really looking forward to it.
Thanks to Mildman too for his write up on engine swaping.
Posted on: 2009/2/2 4:22
Re: Engine swap - Half-way through.
good work but a12 toa14 not a hard swap... if you have the mounting brakets that move the engine mounts the 2 inches required. shouldnt need a different drive shaft though? if manual to manual
Posted on: 2009/2/2 4:28
Yeah the gearboxes were different. One thing being my A12 gearbox had 2 sensors on the side of the box. The box off the A14 only had one and nowhere to put the "missing" one.
I know pictures would help describe what I'm talking about but I'm at work at the moment... umm "working"
I was under the car putting the shaft back into the gear box, goes in fine but then went to the back of the car to bolt it to the diff and there was about an inch worth of gap. If I pulled it back to actually do it up the front of it was still on the spline.
How much play can you have?
Posted on: 2009/2/2 4:43
