bit of a shed cleanout PRICE DROP
From Darwin NT
looking to sell some of my datto stuff
a12 complete was running when pulled out been siiting undercover not in the weather - $150
2x 56a 4 speeds out of a 120y not sure on cond - $25 each
performance globe wheels 14x7 offset is around 20 $150 for the set pics are in my photo album
corolla maybe 120y?? borgwarner diff no axles maybe no center havent opened it $10
bw diff out of a sigma or something is 4 stud (datto pattern) im sure its complete may have bit of the centre missing havent opened it since ive got it home is larger then the corolla and 120y bw's $30
couple of round port heads all incomplete in some ways $10 each SOLD
same sided intercooler bought off ebay havent used it just sat around perfect for a series turbo setup normally $250 on ebay -$200
can pick up from here or can take it to sydney when im going that way again
EDIT can post at buyers expense
Posted on: 2009/2/24 10:48
current project 4x4 patrol...
Re: bit of a shed cleanout
From Darwin NT
also have a 1200 ute diff (h165) complete has the bluebird disc brake upgrade mounts modded to suit 1000 direct bolt in is currently stripped and is welded 4.11 ratio perfect for a 1000 race car or even for streeter that keeps breaking the h145
looking for around $275 ONO
also have a mostly complete 120y struts have the rotors and calipers around somewhere $20
will take reasonable offer on all the other stuff dont be shy i need the money and space
Posted on: 2009/2/24 11:19
From Darwin NT
bump
Posted on: 2009/2/25 5:20
From Darwin NT
bump
Posted on: 2009/2/26 1:30
Quite a regular
From Inner West Sydney
PM sent re heads.
Posted on: 2009/2/26 4:27
From Darwin NT
bump
also have an A12A motor (AKA the big block a12) for sale is missing the dizzy and fuel pump and head
still has oil in the sump and still turns over being an a series id say you could slap a head on it along with fuel pump and dizzy and she would fire right up
$150
dont forget these came with a 75mm bore standard so you have the potential to bore them out further then an a12 and still keep a short motor!
Posted on: 2009/2/27 3:25
From Sydney
PM sent, 1200 diff
Posted on: 2009/2/27 7:30
From Darwin NT
bump
Posted on: 2009/2/27 23:42
From Darwin NT
bump heads are now gone want the rest gone to
Posted on: 2009/3/1 8:35
From Darwin NT
bump
price drop on most stuff
Posted on: 2009/3/2 6:11
