coilovers on the rear of a 1200 ute ??
From perth airport
im shore there's a few guys out there that have done the conversion , but a search brought up nothing helpfull , i guessing most are too long ?
Posted on: 2009/3/15 5:46
perth airport parking
Datsun 1200 ute A14
Re: coilovers on the rear of a 1200 ute ??
From Geelong, Vic
i think its more the fact that you need to make a 4 link setup first. should be able to get a spax coilover that would be about to size of the ute shock, so you would just run it the same as what the shock does
Posted on: 2009/3/15 9:56
From Rosewood, QLD
there is a place called mcdonalds engineering (i think) that sells full 4 link setups for drag cars and stuff... these could be welded into a ute fairly easily, they even sell shortened 9 inch diffs.
Posted on: 2009/3/15 12:04
1971 B110 sedan project.
2012 Nissan Micra daily.
From perth airport
cheers guys thought you could fit coilovers to a leaf sprung cars after seeing it done on the front of 1000's
still seem's like it could work has a coilover has a shock, so your just making the rear more stiffer sprung buy running the leaf and the coil , or is this a bad idea ?
Posted on: 2009/3/15 12:58
Datsun 1200 ute A14
From Mandurah, Western Australia
As Im sure your aware. With the coil over you have a spring and a damper. By using the coil over in place of the shock on a stock rear end you now have 2 springs and a significantly high spring rate.
For the coil over to be effective the diff needs to be able to move up and down. Hense the 4 link setup. Even with a very soft leaf spring arrangement I doubt the coil over will be 100% effective. And say you only ran the large leaf on the rear, You would be placing that spring under considerable strain and possibly fatigue. As that leaf is holding the whole axle assembley in position.
This ute is turning into a serious weapon
Posted on: 2009/3/15 13:13
From perth airport
cheers guys might go for the ajustable shocks that maddat sells then
Posted on: 2009/3/15 22:00
Datsun 1200 ute A14
From Ballarat Victoria
Some coilovers i want to sell... But not enough travell for the ute unfortunatly. Open in new window
You could get away with a single leaf for diff location and then use coilovers but there wouldnt be much advantage over using just the leaf setup apart from being able to quickly change spring rates for track work.
Posted on: 2009/3/15 23:42
VIC DYNO HIRE
From Perth WA
if u use the coilovers u would get rid of the leafs and make watts links from the front leaf shackle point to the diff, need to make the brackets on diff, would then need a panhard rod too to stop sideways movement.
Posted on: 2009/3/16 0:38
From perth airport
4 link is beyond my backyard skill's :(
Posted on: 2009/3/16 1:15
Datsun 1200 ute A14
From Rosewood, QLD
check out this site... everything you need
www.mcdonaldbrosracing.com.au
this is a future project megastore
Posted on: 2009/3/16 2:35
