engine dyno project
From ipswich
i have my engine now running on the stand
i have a few minor issues to solve, such as most of the guages arent workin yet, possible something wrong with my fuel pump( currently using gravity feed tank, need a new water pump as it leaks, fuel mixture needs tuning as its a bit smokey,turbo is probably stuffed as white smoke appears after a bit of running, and im yet to make somethin to put a load on the motor
my main issue is the altinator and how is it ment to be wired up to charge the battery
Posted on: 2009/4/2 7:09
datsun 1200 ute
* turbo A-series * mandarin mica paint * flare kitted and air dam front bar
xh ford falcon longreach s pack 302ci
rolls on 4 big round things
Re: engine dyno project
you want this
Posted on: 2009/4/2 10:56
From ipswich
nar mine looks better
Posted on: 2009/4/2 12:28
datsun 1200 ute
