bulk lot of 1200 stuff
From Tamworth , NSW
i have a bulk lot of 1200 stuff on ebay
check here
Posted on: 2009/6/10 9:28
Re: bulk lot of 1200 stuff
From Tamworth , NSW
auction ends tomorrow. cheap load of bits..
Posted on: 2009/6/14 8:14
From Tamworth , NSW
here is a list of stuff
MIDDLE SECTION FROM STEEL GRILLE(bit grubby but is fairly straight im sure.)
UTE HEADLINING, BLACK, HEADLINER A BIT SHABBY,WAS IN MY UTE. HAS 3 STEEL SUPPORT RODS.
2xUTE INSIDE DOOR HANDLES.WERE TAN, BEEN VYNIL SPRAYED BLACK.
2xBRAND NEW SEALED BEAM HEADLIGHTS, STILL IN BOXES.
1xBRAND NEW CONDENSOR STILL IN PACKET.
2xAFTERMARKET CHROME UTE TAILLIGHT SURROUNDS(pins have come out of one plug.need pushing back in.)
SET OF SECONDHAND TAILLIGHT LENSES
A14 FLYWHEEL
A12-A15 FLEXPLATE
A12 HEAD.
ROCKER GEAR TO SUIT.(no bolts and not attached to head.)
STANDARD A12 AIR CLEANER HOUSING
A 60x40CM CHUNK OF DYNAMAT
A12-A15 DUAL ROW V BELT CRANK PULLEY.(NOT PICTURED)
PLASTIC FAN AND PULLEY TO SUIT.
A12 CARBY(bit ratty, may need a doing over)
2xALTERNATOR TOP BRACKETS
PAIR OF STANDARD SUNNY STRUT TOPS.
1xROUND 'D' GRILLE BADGE(poor condition, will need a good refurbish.)
Posted on: 2009/6/14 8:18
Quite a regular
i gave you a pm
Posted on: 2009/6/14 8:52
bloody oath
