SMOKE COMING OUT OF EXHAUST...
Not too shy to talk
Hi i own a 72 model 1200 sedan, its running a ca18 and has had alot done to it. The other week i had a new gear box put in and iam still wearing it in. When i give it some it is sweet but when i stop or slow down after giving it a bit smoke seems to be coming out the back not to sure what it is any help would be great. cheers
Posted on: 2009/6/24 22:21
Re: SMOKE COMING OUT OF EXHAUST...
Depends on what color the smoke is. Black? White? Bluish white?
Posted on: 2009/6/25 0:11
Not too shy to talk
its a white ish smoke. comes and goes but like i said when i give it some then stop at a set of lights or something i see this smoke comin past me, is bit embarassing. any help is great. cheers
Posted on: 2009/6/25 0:43
From ACT Aus
well if it's just white then it should be water, like steam. blue indicates oil smoke and black is fuel, like when you run it too rich. so the colour is very helpful in finding the problem.
Posted on: 2009/6/25 1:37
unfamilia wrote:
You have bump stops? Your soft
Not too shy to talk
just took it for a drive, blowin black smoke smells like fuel. maybe runnin rich????
Posted on: 2009/6/25 1:44
Edited by 1200oneof on 2009/6/25 4:01:45
Black smoke is either 1) running too rich or 2) bad ignition (partially burned fuel).
Posted on: 2009/6/25 4:15
Not too shy to talk
cheers for your help, its winter now so its ready for a new tune. will see if that makes a difference. if bad ignition any suggestions?
Posted on: 2009/6/25 4:49
With a CA18, you shouldn't have to do "a tune". There is no points to set, timing shouldn't change, and no carburetor.
Something is else wrong, sensor gone bad or something. Perhaps the engine has been modified or is missing some sensors.
Posted on: 2009/6/25 4:56
From perth airport
you running a after market ecu ? could be the tune is safe and a bit rich ( fairly normaly )
could be the carbon canister getting over loaded
could need new plugs as the old ones arnt bruning all the fuel
Posted on: 2009/6/25 5:10
perth airport parking
Datsun 1200 ute A14
Not too shy to talk
yeh its got a microtech LT10, will give the plugs a look at cheers for all your help guys.
Posted on: 2009/6/25 5:28
