Nissan Nomad?
From Oberon NSW {Bathurst}
Anyone know anything about the Nissan Nomad? Do they have any parts suitable for fitment into a 1200 eg motor/trans, brakes ect. All I know is that they were released post C120 Vanette.
gif  Sponsor.gif (16.68 KB)
10229_4a76a3f7c581d.gif 72X72 px
Posted on: 2009/8/3 9:46
Cheers Peter.
nos4datsuns@bigpond.com
peter.maxsted@bigpond.com
0427 138 266
THIS YEARS RIDES & PROJECTS:
Tweaked 2009 AURION SV6(Daily)
Re: Nissan Nomad?
From Adelaide, Australia
They are Z24 motor, this is a taller block than a L20 3/4inch taller actually, but the head is much shorter, probably an easier swap than a L16/18. You'll need to either use the van box with different linkage for the gearstick or use a navara box. L-series box will bolt up but shifter will be at a funny angle.
Posted on: 2009/8/3 9:54
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
Re: Nissan Nomad?
From sydney
Is the Z24 crank used to stroke an L20? wha other internal parts do you need to make that work?
Posted on: 2009/8/3 10:02
Re: Nissan Nomad?
Maybe I do some reasearch and look at fittment into my 64 ute. More space in the engine bay. Hmmmm
Posted on: 2009/8/3 10:04
Cheers Peter.
0427 138 266
Re: Nissan Nomad?
Yes, L20 rods, block needs to be clearanced with grinder and bored to 89mm. Z24 pistons cut down as they will be above deck, ka24 pistons can be swapped for different c/r not sure if they are flattop or not.
Posted on: 2009/8/3 10:10
IPRA Build
Re: Nissan Nomad?
From Townsville, Qld
Here's some nomad disks on my stanza hub on my stanza strut with the nomad calliper. The nomad hub fits on the stanza strut but it puts the disk closer to the face of teh hub which would cause problems for mounting wheels.
Posted on: 2009/8/4 0:53
