A14 spark plug gap, elec dizzy.
From Gawler, Sth Aust
What spark plug gap do you guys run?
I have a bosch gt40 coil with elec dizzy and soon 10mm leads. Any suggestions for other ign enhancements?
Cheers,
Tom.
Posted on: 2009/8/28 2:04
72 B110 A14
71 B110 A12a (Parts)
06 380 VRX
Re: A14 spark plug gap, elec dizzy.
0.043 inch gap with Datsun electronic ignition. This requires a high-energy coil like the stock electronic-ignition Datsun coil. It makes a hotter spark, the bigger gap burns the fuel charge better.
10mm plug lead will make 0% extra power compare to 7mm new plug leads. But they sure will look phat. However, if you go from standard resistive leads to wire leads it makes a slightly better spark, at the expense of radio noise.
Posted on: 2009/8/28 6:46
