L18 Conversion done, BUT couple of issues...
From Mildura, VIC
Guys,
We just completed a built L18 / 5 speed conversion into my brother's 79 1200 ute, and we have a couple of problems I was hoping those in the know could help us with.
1: The coupe looped tacho is wired up as per wiki info, (please see pic) and all we get is some very slight jumping around every now & then when the engine is running. - The tacho wire was the wrong way around (to "-" trigger) & I changed that when I checked it as per the pic. - Any ideas?
2: We are using the early skyline stumpy 5 speed, what model dato do we pilfer a speedo cable from to get the factory 1200 speedo working correctly?
Happy with the build, we are running the engine in but can tell it's a huge improvement over the worked A14 that it had previously. - Much more torque. The L18 was rebuilt with Hypatec pistons, 10.5:1 comp, Anothony Koch spec'd cam & a good port & polish. It's running a jetted down draught weber we had laying around until it's ran in, which will be swapped out for a single 45mm side draught.
jpg  Tacho wiring.jpg (26.55 KB)
12329_4af60cc136779.jpg 550X550 px
jpg  DSC00470.JPG (93.02 KB)
12329_4af60d19cacf1.jpg 653X490 px
Posted on: 2009/11/8 0:13
Re: L18 Conversion done, BUT couple of issues...
From Armidale N.S.W
Looking good mate. Speedo wont be working right even if you get a cable i used a 180b one but i think just a 1200 auto one will fit pretty sure i tried it on my stumpy box with coupe dash. You would need to get it calibrated to be accurate.
Posted on: 2009/11/8 2:21
73 1200 wagon SOLD
From Mildura, VIC
Anyone got any ideas re: the Tacho?
Posted on: 2009/11/8 5:05
From Tamworth , NSW
have you tried another tacho incase the one your using is rooted?
Posted on: 2009/11/8 5:14
From Mildura, VIC
Haven't got another one... :( - My guess is that I very well may be.
Posted on: 2009/11/8 5:25
From Mildura, VIC
Measuring up the L20b for another ute now... :) 0 Wonder if we can get that in without modding the crossmember too...
Posted on: 2009/11/8 8:48
From NZ
In your diagram you have the signal feed to the tacho to the + side of the coil. It should be connected to the - side of the coil.
To work, tachos need:
1) "-" side of coil for rpm pulse/feed;
2) earth;
3) "+" power feed usually via ign switch (although I have a Stewart Warner after market tacho which doesn't require a power feed. It just has earth and "-" side of coil)
The wire to the + side of the coil is simply the coils power feed from the + side of the battery/ignition. By wiring as per the diagram you essentially just have both sides of the coil connected to the + side of the battery.
Posted on: 2009/11/8 9:26
1200 Coupe Racecar, mid-mount A13, C/R 60L g'box.
Previous "Datsuns": B310 sedan worked A13. B310 coupe A14/dogleg 5-spd. 260C sedan, L26, 3-spd man col chng, 6-seater great tow car!. VL wagon, RB30, 5-spd. Nissan Bluebird SSS U13, SR20, 5-spd.[i...
From hastings,vic
the coupe taco picks up pulse from positive coil supply
like pic,not negitive like after market tacos
u have it hooked up right just swap the wires going thrugh
taco loop over[power running wrong way through loop it will flicker]
thats y the black with white trace wire has a male and female connectors
so it cant be connected wrong
tommo
Posted on: 2009/11/8 10:20
taking up room at home
hzj75 cruzer tray(for sale)
and allways changing
200b speedo cable might work out but probably need a recalibration for the speedo.
looking good, doubt you will get l20 in with out sump mods and xmember mods, from looking at pigdogs
Posted on: 2009/11/8 10:31
what radiator did you end up using and fan? single or twin thermo fan on front of radiator(10 or 12 inch/???)
Posted on: 2009/11/8 10:32
