Please help the new guy A12 Carb????
New to this forum and Datsuns and just started a new project I'm hoping someone can help with. I bought a project AH Sprite with a Nissan A12 and I'm trying to do a little engine work. Engine is stock as far as I know other than a header I am building. I want to add a single 40mm Weber DCOE and need to know where to start with jets and chokes / venturies. I've got two carbs to mix and match some parts but I'm sure I will be ordering others. Can some one get me close on initial jetting and choke sizes. I live in Montana and will be running from 5 - 8000 ft.
Thanks
KW
Posted on: 2009/11/24 2:51
Re: Please help the new guy A12 Carb????
From Las Vegas USA
KW just so you don't think folks are ignoring you: while I can't help on the single sidedraught I will tell you that most folks here either use the Weber 32/36 DGEV type, twin Hitachi SU's (JDM Motor) or twin DCOE's.
Understanding that you have the carbs in hand (use what you have) it seems with out some additional work a single 40DCOE might be a bit much for near stock A12. I'd go 32/36 , your header and 2 inch exhaust.
Tom
Posted on: 2009/11/24 2:56
Thanks for the info Tom. I switched to the DCOE because of a hood clearance problem. I have two 40 DCOE's and thought one would be plenty. I can order whatever but one of the carbs has 30mm chokes and the other 27mm. I bought a header that fit the engine but was not even close for the car. I ended up cutting it up and am starting from scratch with a bunch of bends and my Tig welder. I'll shoot for 2" out of the collector
jpg  manifolds.jpg (193.21 KB)
12707_4b0b4d464385d.jpg 800X600 px
Posted on: 2009/11/24 3:05
Here are specs for a stock A12.
Conversion equipment jet setting Datsun B110 (A12)
- single 40 DCOE 2
Choke size 27
Aux. venturi 4-5
Main jet 1-10
Emulsion tube F7
Air corrector jet 1-65
Idle jet 0-50 F9
Accel. pump jet 0-50
Accel. pump inlet valve with ex. orifice 0-50
Needle valve
Posted on: 2009/11/24 3:20
