(1) 2 3 4 ... 9 »
DEDICATED CA18DE T THREAD
From mandurah
ok i though its time to start a CA thread because CA are the main topic we should put all the info in 1 spot so that info is easyer to come by
oh and keep post whoring to a minimum
Posted on: 2009/12/28 15:58
Re: DEDICATED CA18DE T THREAD
be aware that if you dont have your fuel pump output connected(switched to neg) you will not have injector pulse :) found that out the hard way lol.
another quick find i had today for those who want to run thermofans.. instead of paying $50 for a thermo switch. u can get them from jay car in a range of temps from 60,70, 90 etc..
http://www.jaycar.com.au/productView. ... s=thermostat&form=KEYWORD
i will get some this arvo and see how they go
Posted on: 2009/12/29 5:26
From Mandurah, Western Australia
AIRFLOW METER WIRES - courtesy estyre
A= green with yellow stripe
b= black with white stripe
c= black
d= green with black stripe
Posted on: 2009/12/29 5:54
wow, so those thermo fan switchs are mounted on any metal surface? not in the coolant?
so you could almost mount the 70deg one and that gives you a buffer to allow for surface heat transfer. just where to mount it to get a reliable heat temp source for the cooling system?
Posted on: 2009/12/29 9:18
From Perth WA AUS
These things are great so cheap and simple (like Unfamiliar!) but they work well too!
I mounted mine on my top hose and connected it straight to the battery so it would keep cooling after the engine has turned off but the fan goes for ages, Bottom hose works much better.
If connecting to the ignition I would recommend top hose.
Posted on: 2009/12/29 10:12
Datsun 1200 2Dr sedan.
I am gunna mount mine on the radiator tank itself, right on the side.
Posted on: 2009/12/29 14:42
levey can you post a pic, i thought had to be mounted to metal surface? I dont see how would work on plastic top tanks, could always silicon it on , thats simple, effective and cheap (like me too right levey)
im thinking of fitting for my 2 thermofans, one for 70deg and another for 80 deg, likea dual stage set up
Posted on: 2009/12/29 22:03
its just a mini thermostat :) not rocket science. the craig davies setups look like an oven thermostat.
i went for the 70deg ones cause it will be slightly hotter in the coolant itself before it kicks on..
i would be hookin them up to the ignition levey, u dun want em to run for too long ;) maybe get a turbo timer for it? hehe
Posted on: 2009/12/29 23:58
From brisbane
So how do you mount them guys? With silcone or glue?
Posted on: 2009/12/30 0:11
1985 CA18DET Datsun 1200 ute
1969 A12 Datsun 1000 coupe
i would say either, as long as the little pad doesnt get silicon on it should be right.. i am prob gunno glue mine to the rad tank itself with epoxy and or super glue...
Posted on: 2009/12/30 1:36
(1) 2 3 4 ... 9 »
