Possible Blown Head?
From Lisboa-Portugal
After some minutes driving I began to notice a burnt smell fror the engine and today i poped the hood and saw some smoke coming from below the intake and exhaust manifold. Is it a blown head?
I also noticed that some oil is leaking from the back of the head, i thought it was from the rocker gasket but i already changed it and the oil keeps leaking and in the morning there`s always some oil on the floor. What should i do?
Posted on: 2010/3/2 18:33
Re: Possible Blown Head?
It could be a blown Gasket. I haven't heard of any A-series head itself being blown out, as can happen to some engines.
To check on the Gasket possibility, perform a compression check. If two cylinder are normal and two adjacent ones are low, that usually is caused by a blown head gasket.
Posted on: 2010/3/2 19:41
How do i perform that test? Do i need some kind of device?
Posted on: 2010/3/2 19:51
From Christchurch
http://www.supercheapauto.com.au/onli ... 92.aspx?pid=12556#details
OR
http://www.supercheapauto.com.au/onli ... 90.aspx?pid=12574#details
SCrews into spark plus hole then crack the motor over on the starter motor to get a reading.
Posted on: 2010/3/2 22:30
From Nations Capital, Australia
what's your oil like? Milky?
Posted on: 2010/3/3 5:25
The oil is prety clear.
Posted on: 2010/3/3 8:58
