malpassi fuel pressure regulator???
From Canberra, ACT
just wanna know how to set this up?
Posted on: 2010/4/17 5:40
Re: malpassi fuel pressure regulator???
If yhou can take a pic I call tell you what to route where, but in general - the centre pipe at the bottom is the return line. The two on the sides are from the fuel pump and to the carb (and they can go either way from memory) the final one is above the centreline/split and on the same lid/side as tbe adjuster nut. That's the boost reference line from the carb bonnet (you have to run from the carb bonnet, if you run from the intake manifold then high vac at part throttle will open the bypass and return all to the tank and not keep the carb fuel level up.
Posted on: 2010/4/18 12:47
John McKenzie
From Canberra, ACT
thanks for that i did have a picture but it wouldnt load for me thankyou.
Posted on: 2010/4/20 11:16
