120y coupe rear axle
I have a 120y coupe and the problem is, the rear axle is covered full of gunk
and my question is how hard would it be to replace the whole rear axle from a later model
can i get a list of later model axles that bolt straight in?
or would it be easier to replace the diff centre?
i also would like to keep the h145 prop shafte flange
My coupe has the H145 rear axle i think
Posted on: 2010/5/5 4:26
Re: 120y coupe rear axle
From Townsville, Qld
covered as in there's gunk inside where the oil should be?
Posted on: 2010/5/5 8:52
covered as in the whole pumpkin is in a thick layer of hard crusty oil
so indefinately there was a leak before i got the car and the prev owner did nothing about it
therefore i'm guessing the damage has already been done hence the differential noise
Posted on: 2010/5/5 14:50
you could still get away with just replacing the center, the wheel bearings arent supposed to get the diff oil so they're most likely fine. Give it a good degrease and hosedown, you might be able to see any points of damage like missing gasket sections or whatever
Posted on: 2010/5/5 15:25
how would i go about replacing this diff center, and what would i be able to upgrade it to a later model (which bolts straight in?)
do you just take the wheels off, loosen the drum bolts?, and pull the drum out a bit then loosen the pumpkin and replace?
or can i get away with just pulling the pumpkin out and replacing it
i've never worked with differentials so i don't know
Posted on: 2010/5/5 15:47
From gold coast QLD.
You need to buy a workshop manual and read it before you cost yourself a small fortune.
Posted on: 2010/5/5 22:28
Friend if you want sale your car plz let me know.
Thanks
farrukhali28@yahoo.com
Posted on: 2010/5/17 20:48
