PVC valve help
From port elliot , SA
iv got the lynx manifold without the valve on it. and im unsure what to do i know its necissary to release the pressure from the crankcase but. does the valve have to be located in the manifold? can i just take one off of another manifold and mount it on the end of the feed line ?
Posted on: 2010/5/14 7:49
Re: PVC valve help
From Freo
it's located in the manifold, so the manifold vacuum draws out the crankcase gasses..
Posted on: 2010/5/14 7:59
A15 PSI Project Motor
'72 CB750k,
Re: PVC valve help
ahhhhh so i spose ive gotta drill a nice hole in this manifold and tig it in FML
Posted on: 2010/5/14 8:03
Re: PVC valve help
forgot to mention its going on an A14 too
Posted on: 2010/5/14 8:04
Re: PVC valve help
Tig what in? Can you get away with tapping a thread in instead? Neater and less work (no insult to your tig skills )
Casey, I'm almost on the road with my 1000, how far away are you? It'd be good to get some more numbers on the cruises.
Posted on: 2010/5/14 8:13
Re: PVC valve help
yea im having a bit of friday afternooon ITIS haha i just realised the one off the stock manifold is a threaded fitting.
iv been working too hard this week im loosing my marbles.
yea my ute isnt far off im just trying to find nitty gritty stuff that i dont wanna buy new like a headlight and some front apron indicators also need a door seal and to touch up my paint should have the power house done by the end of next week fingers crossed
Posted on: 2010/5/14 8:20
Re: PVC valve help
no one would happen to know what thread tap it is haha
Posted on: 2010/5/14 10:07
Re: PVC valve help
If the manifold that you have is a Lynx D1000 then I have bad news for you.
This manifold does not have a PCV provision because the engine that it was specifically designed for, the A10, did not use a PCV system.
Worse, it was designed for the earlier round port configuration & will not fit & work on an oval port A14 head. [Nor a round port A14 head either]
Click on image for full size picture.
Posted on: 2010/5/16 10:49
Love your Datsun.
Treat it well.
Re: PVC valve help
FML why wouldnt it work on an A14 round port head ? i really wish this #OOPS# was easier :(
Posted on: 2010/5/16 11:55
Re: PVC valve help
Bolt pattern? You may have to drill n tap a new hole (between the existing two studs) for the manifold stud.
Get some pics up of the manifold?
I saw your old wagon yesterday cruising down grand junction road (I think it was yours anyway).
Posted on: 2010/5/16 12:05
