Car doesn’t pull as usual
From Sri Lanka
Hi Guys
I got a wired problem with datto, it doesn’t pull as usual pickup is very low, checked the spark plugs, cylinder 2 plug was wet and all the others were dry and white color as usual, so installed the wet spark plug to another cylinder and ran it and saw then it was dry , so assumed that all the spark plugs are ok ,my mechanic said that ignition coil is bad and leaking electricity, what is the best way to check ignition coil ?
later I checked the contact point it was ok, but rotor had a burn mark , so I sand paper it, still car has the same problem, suddenly for few seconds it pulls as usual then again like a tractor,
When cold start it has a misfire between 2000 -3000K rpm also but only once then after no more misfire.
So what do you guys guess? I want to 100% confirm whether it is really the ignition coil before buying it if not I am loosing 25 $. Or is there any thing wrong with engine cylinder, checked the exhaust tail it is black but no sign of oil burn at all, it is dry
Is wrong or faulty ignition coil will affect only one spark plug to be wet and others to be dry ?
Or is it something with distributor cap? Your help is extremely needed guys.
I got LUCAS Barrel type liquid Ignition coil it is older than 4 Years
Thanks
Regards
sumith
Posted on: 2010/6/28 4:10
Re: Car doesn’t pull as usual
From Nyngan, nsw Australia
you mite have spark jumping to earth.....check rotor cap for cracks, that tend to make it douie
Posted on: 2010/6/28 4:18
living is good,.....
From Sri Lanka
Hi Guys
Come on guys . i need further more ideas and suggestions please..
Thanks
Regards
sumith
Posted on: 2010/6/28 8:56
From Bendigo, Victoria
Sumith, 40 years ago an old mechanic told me to wait till its dark, lift the bonnet and get someone to rev the car so that you can see if sparks are jumping anywhere.Give it a try.
Posted on: 2010/6/28 9:57
From Sri Lanka
Hi Ivan1
That is an great idea, i also thought it earlier actually i was planning this yesterday but i missed the chance, any way i am going to do this .
Thanks
Regards
Sumith
Posted on: 2010/6/28 10:02
From Ringwood, Melbourne, AUS
Check the resistance of the ignition leads, can't remember the value they should be (far to long ago!) but you will notice if one is a lot higher value than the rest.
Posted on: 2010/6/28 11:23
Deano
From Perth WA AUS
If its not dark enough to see the spark try touching all of the lead ends with the motor running, you will know for sure if there is a jumping spark!
Posted on: 2010/6/28 12:02
Datsun 1200 2Dr sedan.
From Toowoomba
Could be fuel not spark????
Posted on: 2010/6/28 12:04
From Sydney, Australia
Sumith,
I don't think your country is famous for high quality fuels...certainly not in some regions.
It's most likely just a poor fuel issue. Maybe it is time to buy a compression tester guage.. They can be bought for between $30 - $200 at the auto accessories shops. Assuming you have them over there!?
It would be a handy addition to the tool box if you are going to keep "cars" as a hobby.
Posted on: 2010/6/28 12:15
have ever you heard of "trial and error"
Posted on: 2010/6/28 13:36
