Browsing this Thread:
1 Anonymous Users
question electronic dizzy |
From malmsbury victoria
gday,im wanting to do the e15 electronic dizzy conversion and read up on it but needing to know with this dizzy do you need seperate module or is it built in.and does anyone know where to get this and what do i have to ask for,for the complete set up?im in central vic.any help would be greatfull cheers nuts..
Posted on: 2010/7/18 12:42
1200 coupe a14 k/cross always looking for that extra edge!!!
Re: question electronic dizzy |
From Sydney
Hi mate, off the top of my head you need a complete E15 dizzy. The moduel is built in. Also get the coil from the same vehicle. You will need to bypass your ballest resistor by joining the wires together and you will need to put the gear from your standard dizzy and base plate to the E15 one and connect it up. The black/white wire is positive and blue in negative on the E15 dizzy. Hope this helps
Posted on: 2010/7/18 14:01
thanks for that,thats all the info i need,now just got to find one!!cheers joel
Posted on: 2010/7/20 0:53
