clutch for 60 series dogleg on 1400
From Sydney
Hi as the title says would this gearbox setup on my 1200 ute with an A14 engine
use a 1200 clutch?
thanks
adam
Posted on: 2010/8/24 12:26
Re: clutch for 60 series dogleg on 1400
From Ringwood, Melbourne, AUS
Just use the std clutch for that engine, think they are all pretty much the same anyway.
Maybe Vanettes have a heavy duty option??
Posted on: 2010/8/24 13:23
Deano
The A12 and A14 clutches are the same size and bolt on
The factory A12 is a light action clutch, and factory A14 is heavy duty.
But most aftermarket clutches are the same A12, A14, A15. No difference.
Only the B210 5-speed clutch is different.
Posted on: 2010/8/25 4:48
From Sydney
excellent news
thankyou guys and gals,
also the gearbox makes no difference?
thanks again
Posted on: 2010/8/25 8:17
All 60-series and 56-series RWD gearbox use the same clutch dimensions.
The gearbox makes a difference in other ways. Nissan did not use anything smaller than 60-series behind an A14. The 60-series floor shift versions are a nice smooth shifting gearbox.
Posted on: 2010/8/25 21:10
