ssskiwi wrote:
3-4 inches is a lot, how much droop does the car have when sitting flat?
What spring rate are you running?
Have seen so many poorly designed setups that have no droop etc. due to too short struts..
Yes i agree, alot of setups have very little to no droop. I use the Mrk1 golf inserts for my coil over conversion. I ended up using 1 inch steel spacers in the base of the strut body. In my opinion the overall free length was still not long enough to have any substanial droop, the LCA's were more or less still horizontal. To overcome this problem I installed some 30mm bump steer spacers and got some decent angle back into the LCA's, the handling improved significantly.
Springs on the other hand were another major hassle to find that ride v's performance trade off. I tried linear springs with tender springs [linear springs are great for setups where where small suspension travel is desired]. To overcome the ride height i wanted i had to install a stiffer spring ~280lb/in to overcome the short shock travel. The ride was harsh. Because the setup was installed in my streeter i wanted a ride that was a bit softer and at the same time perform well through the corners. So in the end the linear springs with the tender springs came out and I ended up installing a pair of Kings single taper springs [KST150]. They work with an exponential response.
The calculated spring rate at the current ride height is 150lb/in but when the suspension travels 1 inch on bump the rate increases upto 210lb/in, you get the idea. Another thing to remember with tender spring setups is that you loose the thickness of the tender spring [when its compressed] from the piston travel measurement. It can be an issue when piston travel is limited. I will see if I can find a pic of the complete assembly.
cheers
benny
edit. The pic shows the comparison of linear springs v's single tapered springs. believe it or not both springs acheived the same ride height, but the ride is worlds apart.
and a pic of the bump steer spacers.
