wrx motor in a datsun 12oo ute
Not too shy to talk
Hi everyone,
I have come across a wrx 2.0l turbo engine and was wondering if it would fit in datsun 1200 ute, if anyone has done this or knows if it could be done any help most appreciated.
can email me specs. rpcarpentry@hotmail.com.
Cheers roc.
Posted on: 2010/10/30 2:53
Re: wrx motor in a datsun 12oo ute
From Tamworth , NSW
i doubt it will fit in there between the strut towers..
surely a tape measure will sort out whether it will fit or not........
Posted on: 2010/10/30 3:06
From Sydney
highly unlikley conversion with extensive mods and 4wd mode, a sr20 would be a much better 2L engine over wrx ones.
Posted on: 2010/10/30 3:08
Ca or Sr conversion is very very $$$$$$ as im finding out :P
Thats with out taking into account the 4x4 side of it. Good luck tho
What state is the motor in at the moment?
Posted on: 2010/10/30 3:12
For a cheap car these datos can get super expensive....!
All the bits for my ute have been acquired, I only need time and a panel beater/painter! Anyone able to help
From mandurah
wouldnt it just be easyer to use a brumby ,they are common as and already have 4 wheel drive
hhmm i wonder how you would go with engineering
Posted on: 2010/10/30 3:26
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
From Gold Coast
there is a bloke on datnet doing a conversion into a 1600, its a tight squeeze even in that! if you did get it to fit you would probvably have to use a different box for rwd only.. tape measure is your friend!
Posted on: 2010/10/30 3:27
From Tamworth , NSW
it wouldnt HAVE to be 4x4
Posted on: 2010/10/30 3:28
From Brisbane
Nope - no way, no how.
They're even a prick to put in a brumby which came with a flat four from the factory.
Posted on: 2010/10/30 4:04
From Wagga Wagga
Mount it in the tray I say would be only way it will fit. Rear engined RWD
Posted on: 2010/10/30 4:47
Not too shy to talk
ok thanks guys realy appreciated, think i might go cai8 just not sur on gearbox as ive seen a few and the gear stick sits a bit back.
Posted on: 2010/10/30 7:56
