What now ?
From Bloemfontein,South Africa
Sitting here wondering what to do. I love my dato but the poor old lady has had a run of bad luck. First a guy rammed her from behind. Tow bar took care of his mazda but also caused the poor girls chassis to bend between the two rear spring mounts on the right hand side. About 3 weeks later there was a nice heat wave which she did not like either so she blew her head gasket. So her whole right side looks like a crinkle cut from the impact on the chassis, motor uses 5 liters of water for 2km driven, water in oil ,exhaust and everywhere it should not be.She is 30 years old and is basically build up out of bits and pieces. The chassis is a datsun 1200 nose with the rest from the cab backwards being a nissan 1400. Motor is stil the standard 1200 rebuild aready a few times from what we can determine.What do you guys think i should do ?
Posted on: 2010/12/20 23:24
Re: What now ?
Wanting to replace the standard a12 with a a14 or a15 keeping the rest of the drive train a12 but will the chassis hold up under the extra power ?
Posted on: 2010/12/21 0:02
