R31 Wheel bearings
From Mandurah, Western Australia
Posting this up as this was discussed a few months ago and it was mentioned about the inherant problems of the cone style bearing used on the R31 diff.
The diff shop that re-buit my unit have fitted normal bearings. They have simply pulled out the bearing seat in the end of the axle housing and used a normal style bearing. Only down side I have found is the retaining flange that holds the axle in place has to be distorted slightly when you tighten the 4 bolts up. To get the required pressure on the caliper mounting.
jpg  diff end.JPG (29.77 KB)
2484_4d19d4f5ba7cc.jpg 448X336 px
jpg  Bearing.JPG (19.36 KB)
2484_4d19d549f3a65.jpg 448X336 px
Posted on: 2010/12/28 12:18
Re: R31 Wheel bearings
From hastings,vic
still looks like a taperd rolla
the outer shell is still atached to retainer
Posted on: 2010/12/28 12:27
taking up room at home
hzj75 cruzer tray(for sale)
and allways changing
From Geelong, Vic
i agree with tommo, there shouldnt be that groove around the bearing if it was a flat roller one
the retaining flange on the borg warner diffs always bends...something to do with being a crappy design
Posted on: 2010/12/30 1:19
Change for R31 Wheel bearings then Required Several tools & accessories are: Jack stand, Jack, Wheel brace, Bearing grease, Hammer, Pliars, Adjustable spanner, Socket set, Spanner set.
Posted on: 2010/12/30 4:49
Car Parts
