A12 piston size
From adelaide hills
hey all im new to datsuns and i was wondering what size the stock pistons are??
also whats the biggest you can go with them??
cheers dan
Posted on: 2011/2/14 10:47
Re: A12 piston size
From sydney.nsw
73mm is std , i have 1.5mm oversize flat tops piston/rings new, if your interested,they can be bored bigger with mods.cheers
Posted on: 2011/2/14 11:00
A.T.E RACE ENGINES: ( " AUST 1 " 2010 ) A15 GO THE DATTOS... 0412 864 741
Re: A12 piston size
As already written, standard pistons were 73mm with three factory oversizes in half mm increments [73.5, 74 & 74.5 mm]
If you use A12A or late model A13 rods you can bore the block to 75mm which is A12A size along with three oversizes in half mm oversizes.
Additionally you could bore it to 76mm & use A13 or A14 pistons. Both of these come in the same three oversizes but pushing it beyond 77mm is probably pushing your luck a bit.
Why the different rods? The 73mm pistons [& oversizes] used a 17.5mm wrist pin while all other models used a 19mm pin.
The A12A & late A13 were simply bigger bore A12 blocks but their rods had the larger eye to accommodate the larger pin.
Later A12 rods were forged with the larger 'little end' but were bored for the smaller pin, These can be bored out with confidence.
I wouldn't actually recommend boring the earlier rods with the smaller 'little end, yet this is what I did in my GX engine in the early 80's & drove it for squillions of miles without any problems.
Posted on: 2011/2/14 11:12
Love your Datsun.
Treat it well.
Re: A12 piston size
From adelaide hills
cheers guys.. especially dodgeman thanks for all the extra info and hints.. i will certainly keep it in mind
Posted on: 2011/2/15 7:32
Re: A12 piston size
From Malaysia
A12A block and A12 block, is there any different?
Posted on: 2011/2/15 7:50
Re: A12 piston size
A12A big bore.
Posted on: 2011/2/15 7:59
Re: A12 piston size
From Malaysia
73mm vs 75mm isn't it?
Posted on: 2011/2/15 10:33
Re: A12 piston size
For all practical intents & purposes the later [rear distributor] A12 block is interchangeable with the A12A with the only significant difference being the bore sizes.
If one is going to go 'big bore' in Australia it is probably better to go to the 76mm bore size & use the readily available A14 pistons as A12A pistons [75mm] for A series Datsuns would need to be sourced from the US.
Posted on: 2011/2/26 22:31
Love your Datsun.
Treat it well.
Re: A12 piston size
Quite a regular
From Olympia, WA, USA
Dodgeman wrote:
squillions of miles
So what exactly is a squillion?
Posted on: 2011/2/26 22:59
Edited by Ron1200 on 2011/2/26 23:20:18
Re: A12 piston size
From Malaysia
do you mean A12A is US only market? my b310 has A12A in it, and none of my friend use A12A. the car is a little different, as my car have the heater. we don't use heater in Malaysia, the weather is scorching here all year :)
Posted on: 2011/2/27 7:51
