Hey guys, ive learnt alot from these forums so heres my build. My build started about year and half ago. I will try and edit the thread as i think of things ive missed.
History:datsun 1200 1979 Metallic pearl blue
worked a12 built/flat top pistons,large cams twin 38s. Bare metal body respray.
I am the third owner bought it off mike and i think he owned it for 1 year.
old plates were AF41TI and mike put on the oda70 - datto ones
Bought car from mike 9/12/06
fun part, parts list
Maddat ca fitting kit
Maddat race coilovers
re-built front end
r31 diff 3.9 min LSD dr datto supplied kazz 2way waiting to be fitted
ca gearbox - serviced
remote clutch kit maddat
short shifter kit
Turbosmart BOV plumb back
Turbosmart 1200 fuel reg
ca cm flywheel
garrett gt2871r .64 rear + gtx35082 trial rear .82
6 boost manifold - now
Quick Spool manifold600x300 intercooler pwr
ca custom radiator pwr
fuel pump 044 x2
70lt fuel tank foam filled
Haltech 1000s
haltech IQ3 Display Dash
ENGINE:ACL race b/e
acl race m/b
cp pistons
spool conrods/fasters
arp main studs
arp head studs
acl/cometic head gasket
tomei poncams 260 8.8
ross balancer single version
full gasket set
ca race springs
cpc custom plenum/runners/fuel rail
tomei adjustable cam gears
spitfire coil packs
8x 534 cc injectors
ok pictures
starting to remove old engine
http://i1181.photobucket.com/albums/x438/Tieslow/P1050700.jpghttp://i1181.photobucket.com/albums/x438/Tieslow/P1050706.jpgold engine out
http://i1181.photobucket.com/albums/x438/Tieslow/P1050720.jpgrebuilt ca18det, bought from forum member - later found out motor was #OOPS#ed bores worn (oversized) and crank cracked.
http://i1181.photobucket.com/albums/x438/Tieslow/P1050694.jpg
