Our Kiwi brothers widening a steelie great stuff
Posted on: 2011/7/26 3:46
Re: Our Kiwi brothers widening a steelie great stuff
From Christchurch NZ
Thats Toby's ute. He packed a sad after I cleaned up a thread with some uneccesary remarks in it, and hasn't posted since. His ute was one of the lendich construction fleet. (A brother of cheater5's ute)
Widening steelies is all the rage here atm. I'm even thinking I might do the steelies on my pb310 just to aid resale value.
Out of curiousity D, you're not registered there as Datso are you?
Posted on: 2011/7/26 4:24
Forced Induction!
From Taupo New Zealand
widening steelies has been done since time immemorial... just not so common these days, although as Bart said it might be making a comeback. we have done them in the past for customers but with alloy wheels being so cheap now it's not that common to widen wheels. is it not done in Australia?
Posted on: 2011/7/26 8:22
1970 1200 coupe A15
1972 1600 original except for nana's sheepskins
1978 B310 SR16VE
It's a time-honored hot rod tradition here in america. But not very common nowadays. That means it is kind of expensive.
I just want some 5" wide steel twelvies.
Posted on: 2011/7/26 8:28
From South East Brisbane
2 questions, if i do this, is it legal, and secondly, how easy is it to cut and weld the steelies together (to cut/weld them true)?
Posted on: 2011/7/26 8:39
datsunikon (fb) | datsunikon (blog)
From Townsville, Qld
I suspect the wheels are jigged for welding and rolled in a machine to sort out final balance
Posted on: 2011/7/26 8:43
From Near Bundaberg QLD
I've got a lathe, I've got a welder, and I'm a boilermaker.
But the chucks our lathe has weigh a fkn ton (12inch dia 3-jaw, and 18in dia 4-jaw, lathe is 8ft bed and 2ft throw, just a wee baby LOL) so not too keen on swapping the 3-jaw with the 4-jaw, don't have a magnet stand and dial gauge to check them, plus i'm not all that confident with the welder doing fiddly work like this (more used to hardfacing and welding up 12mm-32mm plate).
Anyone know a place in QLD who does them?
Posted on: 2011/7/26 12:19
Thanks, Sam-U-El/Racer135
4 utes, 1.5 sedans, 2 120Y sedans, 1 C120, 1 1600 sedan, all look like or are wrecks
Bart yes thats me Datso couldnt use D not enough characters.
Shame about that owner of that thread. Would have like to see
how the ga16de goes as Peter PJZ has the big block brother qc18de
ready to tackle the track, its supposed to be a torque monster
and weighs similar to the a15 fully dressed.
No need for a lathe he guy did it with an angle grinder as far
as he says and just need a good mig welder and welding experience
You weld in small sections for some cooling time & keep rotating.
Edit; I think he used a bench angle grinder with big lever
Posted on: 2011/7/26 14:19
Edited by D on 2012/10/30 2:33:01
From Sydney
A few places still can do it in Sydney... Because its not that common anymore, it seems to attract a higher price these days.
Posted on: 2011/7/27 0:18
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
From mandurah
I know summerfeild engineering in perth can widen wheel
My brother is getting his stock hk holden wheels chopped up and the centers are getting put in 14x7 and 14x8 steel rims
So yes there are still folks that do it
Posted on: 2011/7/27 0:29
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
