drilled brake rotor, are they any good?
From Malaysia
saw a couple of those at the foundry. do they improve the braking? any harm doing that?
Posted on: 2011/8/2 23:48
Re: drilled brake rotor, are they any good?
From Freo
drilling is most commonly used on race brake rotors,
they tend to get heat cracks arround the holes,
Slots have the same purpose and help in keeping the pad surface flat,
Posted on: 2011/8/3 1:25
A15 PSI Project Motor
'72 CB750k,
From Sydney
Dimpled and slotted rotors seems to be the go in motorsport these days...
Posted on: 2011/8/3 2:22
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
From Brisbane
Talked to my engineer about drilled brake rotors and he said don't do it. It weakens them too much. Better to get slotted rotors in his opinion.
Posted on: 2011/8/3 4:29
From Malaysia
i think i don't state my point clearly. those rotors are stock rotors, and the foundry drilled it like that. in my logical view, if even aftermarket drilled rotors tend to crack at the holes, stock is even further. i don't want the rotor to shatter on me. that is possible isn't it?
anybody would recommend me slotting stock rotors on my b310 and 510?
Posted on: 2011/8/3 6:20
