Nissan HB12 Sunny with an E15 engine - troubles
From Harare, Zimbabwe
Hey guys....
I know this is not exactly a Datsun, but I do have one! This Sunny is my wife's daily driver, and has a couple of engine troubles...
A bit of background on this car:
The company I worked for bought this car with a leaking water pump. It was changed but the engine wasn't even given an oil change. After a couple of months, the timing belt snapped when I was driving it & bent a couple of valves. I had the head recon'd & the mechanic that put the engine back together said that it needs rings, bearings & seals. Apparently the bore was still ok , had no lip.
Where my problem comes in is with the way the engine sounds. I know that these engines idle very quietly when is perfect condition. This one sounds like something is loose... The mechanic tried tightening the rockers? followers? then the engine wouldn't start/run. When he loosened them again, it started up. He said it could be worn followers or a worn camshaft. The sound speeds up/slows down with the engine speed & sounds like: prrrrrrrrr!
I'm planning on changing rings & seals soon (it's leaking quite a bit of oil & I check the level every few days)
A few weeks ago I saw an HB12 Super Saloon with a turbo motor, aircon & power steering. I would eventually like to get that engine or maybe another that can give me "full-house" options, any ideas on the engine?
Am I barking up the wrong forum? Does any one know a forum I could get some pointers on for this car?
Thanks for listening guys!
Posted on: 2011/8/4 20:00
"Make a plan!!!"
