Wanted ,MIG welder to borrow ,Perth
From mandurah
As above I need a mig to fix some stuff on my ute
Only needs to weld the top rear mount/tabs back on my gaurds and weld a nut on the bottom of the sill for my gaurds to bolt to as the threads are gone
Ring or txt 0437787966
Cheers
Posted on: 2011/8/29 7:55
Re: Wanted ,MIG welder to borrow ,Perth
Grab niges stick I mean mig
Posted on: 2011/8/29 9:23
From Perth WA AUS
Do it at Damo's house when you go there.
Posted on: 2011/8/29 10:45
Datsun 1200 2Dr sedan.
Playing with stdick or a welder- both?
Posted on: 2011/8/29 11:00
From Mandurah, Western Australia
Drop round and do it here if you want.
Got my new MIG up and running.
Posted on: 2011/8/29 12:08
From mandurah
awesome fellas ,jarrad if your free this coming weekend ide love to do it !
When ever your free let me know and we can arrange something :D
Posted on: 2011/8/29 16:49
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
Pop that cherry.
If you had gas and in melb youcould borrow my mig
Posted on: 2011/8/29 21:44
From Coondle, WA Australia
Jesse, you can come up here and use my mig, or can borrow my gasless unit if you like. You should have asked on the weekend. Hec if you are keen, you can borrow my Mig unit, or the TIG, but you have to go and pick that up and then deliver it to me as part of the deal. Hec the stick welder is here to borrow if you are keen.
Jesse, if you want to make a weekend of it, you can drive up and we can have a good crack at it.
Yellow peril can lift the ute up onto blocks too!
I dont have a plasma cutter yet though, so it will have to be oxy or hand cutting for the steel patches.
Posted on: 2011/8/30 1:45
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
From mandurah
Awesome ,ive got a cig stick so just need a mig
Will see when im free fellas
Posted on: 2011/8/30 4:40
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
180-250amp CIGweld single phase welders come up every now and then second hand for next to nothing. You can run gas/gasless wire thru them as they have swapable polarity so no need for gas if you are a cheapskate.
Around $500 should get you a one in good working order ready to go.
Posted on: 2011/8/30 10:21
