Wanted!! 120y sway bar brackets..
From Sydney
Hey as title states I'm after 2x 120y swaybar brackets I already have the swaybar and rubbers just need the brackets located in Sydney!! 0422853740
Posted on: 2012/1/21 4:58
Re: Wanted!! 120y sway bar brackets..
From Boredomville Melbourne
I think I used the 1200 stock ones and the 120y sway bar bushes fit. Might have shaved them slightly to fit
Posted on: 2012/1/21 8:24
B110 sedan: L series and 5 speeds, the way they should have been
From Sydney
Ok it's cause I was told its a 120y swaybar but it's really thick.. Are 120y swaybars red? Because this is red and it's factory red not foray can or anything.. Just my 1200 brackets don't fit
Posted on: 2012/1/21 8:28
Could be a pedders after market one. The rubbers will be different I thought I used the 1200 metal brackets with the 120y rubbers.
Posted on: 2012/1/21 8:52
From Sydney, Australia
Hi.
You use the 1200 d-shackle bracket with the factory 120y d-shackle bush.
Edit: yeah, what he said
Posted on: 2012/1/21 11:19
From Sydney
Ohk cheers guys
Posted on: 2012/1/21 23:15
