Browsing this Thread:
1 Anonymous Users
Ca18det + Datsun 1200 tare weight numbers |
From Sydney
Hey guys I've just weighed my Datsun ca18 ute n got a shock as to how much it was it was 910kgs complete n running what numbers should I be looking at?? And 550kgs on just front tyres weighed, I was expecting 700-800kgs
Posted on: 2012/6/30 1:22
Re: Ca18det + Datsun 1200 tare weight numbers |
From Logan, QLD
is that with you in it?, I would have expected 800+kg after you add the weight for turbo, manifolds, bigger engine, more fluids, bigger radiator, intercooler, brakes, suspension, wheels, 910kg is pretty steep tho.
Posted on: 2012/6/30 1:55
From Sydney
Yeh I thought so too I would like to know how much things weigh on the ute, motor, box, diff, brakes etc
Posted on: 2012/6/30 2:07
Registered Users Contentmaster Usermaster
Stock with 12" tires it is 710 kg.
Posted on: 2012/6/30 2:21
From Sydney
710kgs stock.... So with a upgraded comodore diff+brakes front n rear of a vn como, 15 inch wheels n tyres, ca18det,box plus all the other little things that add up, cooler, alloy fuel cell, larger/bigger tail sharft, exhaust, spare tyre,
Would this make up the numbers to my weight roughly?
Posted on: 2012/6/30 2:40
Yes
Posted on: 2012/6/30 2:56
Car free
Quote: So with a upgraded comodore diff+brakes front n rear of a vn como, 15 inch wheels n tyres, ca18det,box plus all the other little things that add up, cooler, alloy fuel cell, larger/bigger tail sharft, exhaust, spare tyre, 200kgs difference. I thought that was pretty good considering all the extra's/upgrades.
Posted on: 2012/6/30 3:29
Nah seems about right mine with l conversion was 900kg on the dot. my Lpg tank weighs a but more than a fueltank
I highly doubt stock weights are accurate as.quoted. More like 750 for Ute.
Posted on: 2012/6/30 3:46
From Sydney, Australia
4 door sedan, full interior, s13 ca18det and gearbox, commodore diff and rear brakes, front mount intercooler, trailing arm suspension rear with rear crossmember and panhard rod. 3 inch mild steel exhaust. Spare tire too.
880kgs with fuel on the weighbridge for engineers certificate.
Posted on: 2012/6/30 7:25
'71 Green 1200 Sedan CA18DET Project 99.98% complete '71 White 1200 Sedan 20,000mi + A14T (twin 40DCOE 30/70 cam, extractors) Website: http://www.shoeys.com
From Brisbane
Sounds right, my CA18DET conversion was 900kg, probably heavier now i've redone the interior and added bigger seats, nice marine ply boot etc.
Posted on: 2012/7/2 3:49
