is this the correct water pump? a12
Hey fellas
Just want to know is this the correct water pump for a12
http://pages.ebay.com/link/?nav=item.view&id=170787497103
I heard they come with clutch fans?
Posted on: 2012/12/20 6:48
Re: is this the correct water pump? a12
From South East Brisbane
Yeah mate thats the right one.
The item your talking about (listed on ebay) doesn't seem to come with a fan.
You should be able to find a similar fan at a wrecking yard with the same bolt pattern to bolt on.
Keep in mind the diameter of the fan and the depth so the blades don't foul on anything in the engine bay.
Posted on: 2012/12/20 6:55
datsunikon (fb) | datsunikon (blog)
I cant use the existing on my car?
Posted on: 2012/12/20 7:12
Are you wanting to replace a pump or fit a missing pump to an engine? Different A12s used two different water pumps. Originally they used a long shaft pump. At some point they changed over to a short shaft pump.
The ONE you need is what matches the pump on YOUR engine.
Clutch fan was used on B310 Aircon models. Also newer Vanettes.
Regular non-AC fan came in two versions - same diameter, same bolt pattern but different offsets.
Posted on: 2012/12/20 7:16
I have a 71 sedan its leaking water from the pump
Posted on: 2012/12/20 8:09
Just be sure it is the pump that has failed. 9 times out of 10 it is the gasket, which costs about $6.00
Posted on: 2012/12/20 8:40
Oh #OOPS#, I thought the fan you were talking about was the plastic bolt on one, sorry man!
Posted on: 2012/12/20 8:41
