From mandurah
welcome to the club ! ,firstly when you undertake such a conversion the stock brakes, diff ,fuel lines ,suspension setup will all have to be changed/modded to suit
its alot of work! but if your willing to pay the 10g (or there abouts) to do it then its worth it
first the old motor will need to be pulled out ,easy to take out with the box attached ,just remove tailshaft ,gbox mount and then all the wiring ,and plumbing and stuff off the motor ,unbolt the engine mounts and bang itll lift out ,to make working on a ca powered 1200 easyer ide sudjest chopping the rad support ,then motor and box can go in alot easyer and less chance of damaging stuff
next either make your own mounts on the stock crossmember or just buy a maddat kit ,itll make the motor bolt in and isnt too expensive ,then its a matter of upgrading the front discs to a bigger model datsun(stanza/180b/200b) and fitting the struts to suit ,then the rear will need doing ,if you run a skyline diff itll need to be cut down which can be pricey but then youll have r31 rear brakes ,next is tailshaft ,get a shop to do it ,cost around 500 balanced and all
then theres fuel pumps ,radiator ,exhaust ,intercooler piping ,intercooler ,hydro clutch setup ,and the wiring on the motor aswell as all the fiddly bits that are needed to get it all to work ,and be reliable
cheers
Posted on: 2012/12/29 19:25
