datsun 1200 ute front 1/4 window help
Quite a regular
From gold coast, qld
I've just put new front 1/4 window rubbers and pit the windows back in , the only thing is there is a small gap between the window and rubber in the front corner on both sides ..enough for water to go inside the car ... Any help is appreciated thank you
Posted on: 2013/1/22 23:59
Re: datsun 1200 ute front 1/4 window help
From Nyngan, nsw Australia
even when screwed in position...you put in the right side??
Posted on: 2013/1/23 0:03
living is good,.....
Quite a regular
Yea there both in the right side and in poisition ..its like at the very front curve up the top
Posted on: 2013/1/23 0:08
aftermarket door or original, did you compare to the original rubbers!, they are a fiddle sh1t to fit, some times a little WD-40 helps rubbers slip in position
Posted on: 2013/1/23 0:13
Quite a regular
It's original .. and yea there geniune Nissan rubbers .. I compared both and looked identical ..haha biggest #OOPS# fit for such a little part ..everythibgs perfect its just that little gap up top doing me over
Posted on: 2013/1/23 0:21
yeah theres a reason i suppose is keep purser veer, been "ORIGINAL" you'd think it fit snug...goodluck
Posted on: 2013/1/23 0:24
Quite a regular
Yea ill keep trying ...do you know what that mouldable black stuff is that holds the Bailey channel in up top ...its almost like black blu tack
Posted on: 2013/1/23 0:26
