Thaughts on running no brake booster?
From Narellan,Sydney
I'm thinking running no booster just a good quality wilwood master.its only a weekend driver so not real worried about the efforts to push the pedal.what size bore would people suggest and whats your thaughts on this for people who have driven both? Iv built it to be more of a real drivers car then to just kick back and relax :) would also have a much neater bay without a booster
Posted on: 2013/8/20 11:41
All stainless steel-mild steel Sheetmetal and tube work
All types of welding
Custom metal polishing
BSA custom fabrication 0415 904 474
Re: Thaughts on running no brake booster?
I prefer no booster. Once I work out how to get rid of it in the stanza its gone.
Run a 7/8 possibly. I was running 11/16 with 4 spot front but drums in back. Now 13/16 same set up but boosted. Prefer non boosted feel.
Posted on: 2013/8/20 12:24
Yeah I was thinking 7/8.i have fairly big ba ford front calipers and r31 rears.i can't say Iv really driven without a booster but I'm sure It wont be a drama
Posted on: 2013/8/20 12:41
From Melbourne AUS
+1 for no booster
just consider that if you need to engineer the car for road use
having large brakes may require too much pedal effort to pass the brake test
that said, i'd still prefer no booster even with the extra effort required
Posted on: 2013/8/20 13:20
1973 B110 A12
From Melbourne, Australia
7/8 will be too big for no booster i think, there will be near zero brake pedal travel and the brakes will be locked up
11/16 is great for me with 4 wheel discs, 4 pot callipers on front. never too much travel (including racing around phillip island)
Posted on: 2013/8/20 13:34
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Thsnks ange.enngineerings all good the moment :) I'm going to run no booster and see how it goes :) thanks
Posted on: 2013/8/20 13:35
i got engineered too
Posted on: 2013/8/20 13:36
1200 Coupe Rallycar
11/16 is the stock size for Datsun 1200. So just run the stock disc brake master cylinder.
Posted on: 2013/8/20 17:25
Dd Why would a run such a small master when I have massive brakes wen the standed Datsun master was intended for small brakes
Posted on: 2013/8/21 0:14
Consider 1200rallycar's experience:
The 11/16 "standard Datsun master" was not necessarily "intended for small brakes". It primarily was chosen to balance out the leg pressure required against the size of the pistons.
With larger brakes, the pistons are farther away from the center, thus more leverage requiring less pressure to stop faster. If instead you are using small-diameter rotors with large calipers, I agree that a larger master with a booster would be called for.
Posted on: 2013/8/21 2:43
(1) 2 3 »
