ca18 question
From Port Douglas. QLD
Hi again,
reducing the coolant lines in my ca before the install. eliminating the connection to the intake plenum
and deleting the heater. after reading the driftopia site i just need a couple things clarified if
anyone can help.
Where the stock oil cooler pipe runs back into the rear of block there is tee in the pipe....can i plumb a line from this to the turbo or is it a return only? also if i cant run a line from there, can I run one direct from the outlet at the back of the thermostat housing (above coolant inlet) to the turbo?
cheers
Posted on: 2013/11/4 9:51
1200 ute
ca18det
