now sourced :-) Wanted H165 diff 4.875
Not too shy to talk
Hi all
Just need a good H165 diff centre with a 4.875 ratio to go into my B310 Sunny rally car.
I believe they were in commercials such as vannetes and 1200 utes.
I am located in Melbourne, any help much appreciated.
Cheers
Michael
Posted on: 2015/7/9 23:09
Edited by micktruck on 2015/7/10 6:36:55
Edited by micktruck on 2015/7/14 5:10:41
Edited by micktruck on 2015/7/14 5:11:19
Re: Wanted H165 diff 4.875
From Newcastle (NSW)
HI Mick,
I have a 'Vannete' H165 diff centre here. Its 4.875:1 ratio and WELDED up to suit a rally car or track car only. It has been sitting around for a few years now so it needs to be cleaned up and a new set of bearings thrown at it before you use it. Otherwise it is fine. What will you offer me for it? Its located near Newcastle NSW.
Daniel.
Posted on: 2015/7/12 3:30
Racecar spelled backwards is racecar!
Now sorted-:-) Wanted H165 diff 4.875
Not too shy to talk
Hi Daniel
If the crown wheel and pinion and housing are good, with no wear or case hardening chips on the drive faces of the crown wheel and pinion [most important], I can swap the centre, as I am not a fan of welded diffs.
I am going to replace bearings and give it a clean up anyway.
You have a price in mind? Any idea how freight would be?
Cheers Michael
Posted on: 2015/7/12 23:29
Edited by micktruck on 2015/7/13 4:03:43
Edited by micktruck on 2015/7/14 5:09:52
