H165 LSD
From Warburton vic
I know it's been a big topic here for years. The Nissan LSDs are so rare.
Has any one used the LSD kits made by traction concepts. There not very expensive & seem like a good alternative
http://www.tractionconcepts.com
Thanks
Coops
Posted on: 2016/2/22 20:00
Re: H165 LSD
Sounds like a spring-loaded LSD instead of the conventional clutch-pack LSD. For an overview, see our tech article: Phantom Grip
Posted on: 2016/2/22 22:04
Re: H165 LSD
From Creswell, Oregon USA
Traction Concepts is Phantom Grip.
Same company.
Our H165's and H145's are small enough chunks of material I wonder why not one person has ventured out to machine LSD case bodies for these differentials?
Posted on: 2016/2/22 22:36
Edited by Mattndew76 on 2016/2/22 22:58:51
An idea doesn't work unless you do.
Instagram @MD_Machine
Parler @MDMachine
Re: H165 LSD
From Mordialloc Victoria 3195
Topgear made some torsen style LSD years ago - I managed to score a new one not used on a project, and yes they are great, better than the 1.5 way clutch type I got from Santora works Japan.
If some one decides to make them again I,m up for another for sure
dp
Posted on: 2016/2/23 6:26
keep it simple
Re: H165 LSD
I would see if I could machine a CLSD body for my 145 axle but the previous owner welded the spiders. This car is a bitch to U-turn in lol.
I could Scale down a R160 CLSD I have sittin on my bench.
Posted on: 2016/2/23 17:12
Parler @MDMachine
Re: H165 LSD
From Sydney
I have a Nismo H145 LSD unit on the bench, if a talented machinist wants to have a crack at replicating it. or at least copy the dimensions into CAD [or similar] from which a CNC clone could be made etc.
cheers
benny
Posted on: 2016/2/23 21:56
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
Re: H165 LSD
Oh nice!! I'm on the wrong side of the planet to take advantage of that.
Posted on: 2016/2/23 22:25
Parler @MDMachine
Re: H165 LSD
From Freo
NZ Dattoboy.... chime in here bro... :)
Posted on: 2016/2/23 22:28
A15 PSI Project Motor
'72 CB750k,
Re: H165 LSD
R160 great idea!
Posted on: 2016/2/24 0:21
Re: H165 LSD
R145 better idea! Keep it light, unless you need heavier duty. R145 fitted to N14 and Murano and many others, and both factory and Nismo LSD are available
Posted on: 2016/2/24 0:29
(1) 2 3 »
