Fuel Sendor Unstable
From Sri Lanka
Hi Guys
My b210 fuel guage is not stable it runs to E when the car moving sometimes it stays without any problem , pulled the sensor and checked with the multi meter in some point Resistance stays calm am some point it shakes up and down, i cleaned it with 1500 grit sand paper it is little more better than earlier but not stable, do i need to replace my fuel sensor or just a clean up with contact cleaner or slimier will sort it out this issue ? any idea what should be done ?
thanks
regards
sumith
Posted on: 2016/3/3 4:37
Re: Fuel Sendor Unstable
The usual problem with the fuel sender is rust/oxidation. The foolproof solution is to replace the bad unit. I haven't had any success in cleaning them
Posted on: 2016/3/3 7:23
