Browsing this Thread:
1 Anonymous Users
4A-GE ute for sale |
Registered Users Contentmaster Usermaster
http://www.gumtree.com.au/s-ad/gymea- ... atsun-1200-ute/1122825409Quote: 4AGE Datsun 1200 ute - Gymea Bay
Selling my project Dastun 1200 ute. I have built this over 4 years and it's got many hard to find genuine parts on it which really does make it one of a kind. Reason for sale is due to buying a property I can lo longer afford to keep going any further on it. The ute has a full AE86 conversion under it, JDM 4age, JDM T50 gearbox, AE86 full front struts, brakes, LCA's, brakes, caster arms and steering arms along with a full AE86 rack and pinion conversion and AE86 diff centre into the original datsun diff housing.
Full specs: 1976 Datsun 1200 ute Brand new bolt on panels and brand new floor pans, G/box tunnel, sills and passenger rear quarter welded in Toda AE86 fully adjustable front monotube coilovers Rebuilt JDM Ae86 fron calipers w/ new pads New tierod/rack ends Rebuilt AE86 steering rack AE86 powersteering arms JDM 4age + T50 gearbox all with custom mounts Mikuni RS40 motorbike race carbs on custom manifold High Rise extractors Custom 2 1/2" exhaust Custom tail shaft Rebuilt rear diff w/ AE86 4.11 diff centre R31 rear disk setup with rebuilt calipers Reset rear leaves with roughly 50mm lowering blocks Rear leaf brace Complete respray in an 80's style green JDM fender mirrors Jap styled fender indicators New tail lights, headlights and front parkers/blinkers Fully tucked wiring loom Hyperpak ignition computer New coil, rebuilt dizzy and new leads Datsun 240K dash instruments installed and working Original Dastun 1000 sports horn pad mounted to a Genuine Nardi woodgrain wheel New Sony head deck with 6" speakers New clutch master cylinder Ke30 brake booster with R32 non ABS master cylinder Genuine SuperStar SS01 wheels 13x7 -2 New Nankang 155/50 tyres Excellent condition original bumper bar Original sun visors in Good condition New roof lining 2x Bride reclinable bucket seats Facet low pressure fuel pump Push button starter/immobiliser restored dash pad Mazda RX2 alloy radiator Full wire wheel/seam seal/tar spray of underside Air dam style front lip GX front grille emblem KE70 combination switch fully wired in and working New black carpet Aerocatch tailgate latches
Things that need finishing: Engineering Final check over all electricals RH front brake line needs a re-flare as it leaks a little bit Door trims to be made/installed Tenneau cover over the tray (personal preferance)
The amount of hard work and time gone into this is huge so I feel that the price reflects that and how little there is to be done to finish it and get it registered. The car is currently having the carbs tuned so will be unavailable too view until it's back in about a week or so. Engineering will pass quite easily, the engine, suspension and brakes are all out of the same car so there'll be no issues with that.
At the moment I'm just testing the waters on what peoples response to this are. If you're seriously interested please text me and I'll call you back. Car is located in Sutherland Shire, Sydney and will be sold as a tuned, running car. I do realise that $17,500 might sound quite expensive, but there needs to be a point to negotiate a price from.
If anyone wants a heap of photos and a build log you can check the cars transformation on this forum: http://www.ae86drivingclub.com.au/for ... hread.php/78637-Sunny-Ute
Cheers
Posted on: 2016/9/7 1:48
